Fuel line routing
Re: Fuel line routing
Ditto.
Plus position the pump below the boot floor not in the boot area ( I don’t Know what the latest installation says).
Mine is bolted underneath the boot on the lower rear bulkhead and then covered with a small Ali cover to keep the muck off.
PS and I still get smells in the boot!
monster7
Post by monster7 »
Dear both,
thanks for reply. Shut off valve is already in place.
I'm in the process to change to an intank pump as i switch from carb to EFI (complete pump system from Tank Inc.). Thereof i have to close the hole. BTW it seems to be M14x1.5 :)
