Help please
Re: Help please
To make it more looking like original, sand down the front edge. Doesn't matter if GRP or aluminium, it was only max. 2 mm thick.
Re: Help please
I have closed the holes with duck tape from the inside to avoid too much "dirty air"
CobStang
Re: Help please
Post by CobStang »
I have now commissioned a new bonnet to be made with a 45mm high scoop as per original BRA. I have been loaned a bonnet for this task and have been able to contour it to my car. The bonnet will be made over size to allow for trimming, it will be a top skin only, I will make a support tube frame.
I will own the mould, so if anyone needs a replacement or lightweight bonnet that should fit any other Cobra pls get in touch.
