Well, that didn't fit
Re: Well, that didn't fit
Post by agnoraan » Tue Mar 05, 2019 7:48 pm
The cars new decals, embracing the wide arched Modsports cars form the early '70's. All period correct decals for the 1970's STP "Modsports" series
Post by simonjrwinter » Tue Mar 05, 2019 9:08 pm
Very nice!
Post by agnoraan » Tue Mar 05, 2019 9:48 pm
Thank you Simon :-)
Post by amulheirn » Wed Mar 13, 2019 9:26 am
Yeah - great work!
Post by agnoraan » Sun Apr 14, 2019 5:33 pm
It's nearly time to fit the down draughts to the car. Most people don't seem to fit filters to the carbs, but I wanted to fit 63 mm tall ones to ensure the engine gets enough airflow. However, the hood scoop on the car is too low to accommodate that, so as this is a Modsports inspired car, I guess anything goes, so I made a taller scoop. I have a spare bonnet, so I enlarged the scoop on that one and I'm currently in the process of taking a mould from it. here's the progress so far
Not bad for 5 hrs work, I thought it'd take longer than that
Post by simonjrwinter » Sun Apr 14, 2019 6:23 pm
Oh, that’s going to be good...👍
Post by StewbieC » Sun Apr 14, 2019 9:23 pm
Great job as always Nige 👍
Post by peterc » Mon Apr 15, 2019 8:04 am
Hi Nige,
Do you use a block of hard foam or plaster of Paris to create the initial shape.
Looks like you have chosen the moulded in and not the riveted on look.
I thought the dellortos were lower than the equivalent Weber’s.
It would certainly be nice to see the completed set up.
I still wonder why they choose to blank off the rearmost cylinder waterway.
Post by Migge » Mon Apr 15, 2019 10:00 am
Nice evolution Nige. At the Techno Classica Webcon presented a new John Eales manilfold wich is a bit flatter and gives you more space under the hood because it's more centered. For Cobras not the business but for Hot Rods.
Post by agnoraan » Mon Apr 15, 2019 8:20 pm
Hi Peter, the bonnet is a spare Viper one I've had for a while. The scoop on that is exactly the same as the one on my car, so I've raised it by 30mm at the front and 20 mm at the rear. I screwed some mdf to the top of it first to raise the height and then filled it and sanded it down to get the shape. If I'd fitted the 45mm K&N filters, they would have just fitted under the hood, but they're marginal for flowing air. I've decided to go for 63mm tall filters which should flow enough air according to Eurocarb the Dellorto and Weber specialists. Once the new scoop is laid up, I'll cut the one off my bonnet and then rivet the new one in it's place, with some sign writing on its sides 🙂
Migge, that intake does look nice, but as you say, it's not quite right for a Cobra
