rear shock absorbers
ianm
Re: rear shock absorbers
Post by ianm » Sun May 17, 2020 4:51 pm
Stuart,
I imagine the bolt hole is in much the same place as your lever arm unit mount. According to my manual of the time Gerry was offering a conversion bracket that used the same mount as the lever arm unit so the bolt hole in 2001 and later chassis is possibly obscured by any lever arm unit. I am sure Gerry will confirm the date of your chassis number and may even still have the option of his conversion bracket if necessary which would then allow you any choice whatever age your chassis. Please let me know if you still need a photo and I will get you one when I can get the car out.
stu60
Post by stu60 » Sun May 17, 2020 6:05 pm
Hi Ian
Gerry has sent me a picture attached and I am not going mad I definitely don’t have this tube.
Think I’ll just get arms overhauled, thanks for everyone’s help
Stuart
ianm
Post by ianm » Sun May 17, 2020 6:15 pm
Stuart,
If you have the 17 digit chassis number then the 11th to 14th digits are the year and month. mine are 0108, 2001 August. This might complete your puzzle and explain the missing bolt hole if yours is earlier.
Hope you finished the grouting.
Ian
stu60
Post by stu60 » Sun May 17, 2020 7:24 pm
Hi
I should have looked before
Chassis number is STSLHAWKC01001281, I think this means it was made in 2010 month 01, registered August 2011.
Strange it doesnt have the tubes then
Stuart
ianm
Post by ianm » Sun May 17, 2020 10:15 pm
Stuart,
As you say, strange. If you are sticking with the lever arms then maybe it does not matter but I am sure Gerry can help you sort the mystery.
If you find an explanation please post it.
Ian
stu60
Post by stu60 » Mon May 18, 2020 9:46 am
Hi Gerry has replied saying my chassis is October 2001 number 281 so was 10 years before registered! Guess it explains missing tubes
Stuart
frats289
Post by frats289 » Thu May 21, 2020 8:34 pm
Stuart
I have Gerry's telescopics on mine, presume they are the same as the Moss conversion. Having had a gut full of A35 and Frogeye Sprite rebuilt lever arms, which failed after a few miles, I opted for a change. Simple conversion and I have them set quite soft - no probs with ride and you can wind 'em up for a track day.
The only way to deal with lateral movement is with a Panhard rod.
Did you know that a 250 GTO has a live back axle!...
Frank
frats289
Post by frats289 » Thu May 21, 2020 8:54 pm
Stuart
Chassis no. 94014 and I have 37.5mm spacers under the springs to the mounting plates for the shockers as I used to 'crash out' under full compression.
have fun
Frank
JakeAustin
Post by JakeAustin » Mon May 25, 2020 9:32 pm
Hi Stuart
I have also contacted Gerry regarding the telescopic dampers. My car is an early chassis aswell and therefore requires the separate brackets. I’d be keen to know what you decide to do.
Jake
stu60
Post by stu60 » Mon May 25, 2020 11:42 pm
Hi Jake
My lever arms are currently being rebuilt at Stevsons in Birmingham. Apparently he is only one who uses Armstrong proper seals etc and is offering a 2 year guarantee. Hopefully put them back on this week with new drop links and see how it goes. I would've interested to see what Gerry says re conversion bracket... This wasn't an option he offered me but then I didn't ask after finding out I don't have the tubes.
Whilst off the road I took opportunity to fit some new leather Cobra SS seats. What a pain that was trying to find locations for bolts through the floor that avoided chassis rails, fuel lines, handbrake mechanism etc. I think if I was doing it again it might have been quicker to remove the exhaust.
Regards Stuart
