Binding Brakes
Binding Brakes
My MGB based brakes have always lacked bite but after passing its MOT my local garage said the servo wasn’t working. This was replaced and as the front brakes were now binding they also replaced the callipers. Still binding, they then fiddled with the balance bar, which aggravated the problem. Am I right that the only thing left is to replace the right hand master cylinder? The rear drums seem to be operating normally. Chris
Re: Binding Brakes
I had problems bleeding mine, something silly and i can't remember exactly how I solved it.
Something to do with getting full stroke on the master cylinder that enables fluid to be drawn back in. When connected to the balance bar it prevents this from happening .
I would try independently first before swapping anything else out. Disconnect the rear master at the clevis on the balance bar and try it then.
It could be the balance bar is holding the brake on slightly.
Hope that helps even if it just eliminates one probable cause.
Re: Binding Brakes
Hi, did the binding only start to occur after the servo was replaced?Henryhawk wrote: ↑Mon Aug 23, 2021 8:26 pm My MGB based brakes have always lacked bite but after passing its MOT my local garage said the servo wasn’t working. This was replaced and as the front brakes were now binding they also replaced the callipers. Still binding, they then fiddled with the balance bar, which aggravated the problem. Am I right that the only thing left is to replace the right hand master cylinder? The rear drums seem to be operating normally. Chris
Is it a genuine branded AP/Lockheed/Caparo/Liberty/920E servo unit - now made by Shiftec?
Regards, Martin.
Re: Binding Brakes
Thanks to you both for your advice and regarding your comment Martin about the servo, yes the binding seemed to start after replacing the servo. I purchased it from Rimmer’s but I don't know the make just their part number GSM125P (for single circuit brakes) as per the old one. Chris
Re: Binding Brakes
Hi Chris, PM sent .Henryhawk wrote: ↑Tue Aug 24, 2021 3:58 pm Thanks to you both for your advice and regarding your comment Martin about the servo, yes the binding seemed to start after replacing the servo. I purchased it from Rimmer’s but I don't know the make just their part number GSM125P (for single circuit brakes) as per the old one. Chris
Regards, Martin.
Re: Binding Brakes
If there are any words of wisdom on this topic, please share them.
I too have brakes that bind intermittantly, well do not release immediatly - single pipe system, AP Lockheed servo, discs all round and Tilton proportioning valve. It was suggested that the air inlet filter to the servo was blocked so I spoke to the nice man at Power Track Ltd who sold me a rebuild kit for the servo. Servo subsequently rebuilt and problem solved...for a while, back again now.
Any words of wisdom would be appreciated.
Frank
Frank
Re: Binding Brakes
I don't have a servo fitted so can't comment on whether or not it is the cause, however I've never had any binding issues with my Princess 4-pot callipers. Personally, I don't see the need for a brake servo in our cars.
Re: Binding Brakes
I would be looking at the master cylinder seals.
Had this issue many moons ago on my V8 MGB.
Would bind up until the brakes were smoking.
Mine was master cylinder seals.
