RV8 parts for sale
StuBaker
RV8 parts for sale
Post by StuBaker »
RV8 parts for sale, removed for SBF engine swap.
Postage extra, tbc.
**NOW SOLD **Hawk tubular manifolds, pair, uncoated, only used last summer, includes studs, £350**
Alternator, 65A Prestolite 66021637, £70
Propshaft, Hawk, RV8 to Jag, £150
Malpassi fuel filter regulator, glass bowl, FPR004, £30
Rover oil pump prime shaft £5
**All new, only used last summer.
LT77 gearbox with shortened remote, £100
** Now sold ** SU Carbs and inlet manifold, £150
**Original '78 SD1 but usable.
Ford solenoid relay £20
Re: RV8 parts for sale
Are the manifolds carbon steel or Gerry’s latest St Stl items?
StuBaker
Post by StuBaker »
Hi Peter,
They’re mild steel from Gerry. Just a protective paint coat.
FIAJack
Post by FIAJack »
PM sent,
Jack
FIAJack
Post by FIAJack »
Hi Stu,
PM still sitting in out box. I'll take the manifolds if still for sale.
Jack
rhattersley
Post by rhattersley »
I don't suppose the LT77 remote is still up for grabs...?
StuBaker
Post by StuBaker »
Yes it is. It's a shortened one. I'll add a photo for you to assess.
rhattersley
Thanks Stu. That'd be great.
StuBaker
Post by StuBaker »
Hope these help.
It has original bushing etc.
It is solid mounted
The small dangly bit on the side is where the speedo sensor picked up the propshaft bolts
note: only use two bolts for detection, turn the other two opposite way round. They are not equidistant and this eventually confuses the speedo!
rhattersley
Hi Stu. I've sent you a private message to discuss things further.
